Question about disc conversion!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SlyDog, Mar 10, 2002.
  1. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Do you have to use the rotors and calipers from the same year as the 14 bolt ? Thanks !
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    No. What is the underlying question/problem/goal?
    Only recently has the 14 bolt been introduced with disks but I don't think you are talking about this option.
    You will need to decide on calipers (e-brkae or not is the biggest decision) and then get the backing plates from the people on this site or other vendors.
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    You can use rotors and calipers from a 70's front Dana 44.
    Go to Autozone and tell them you want some rotors, brake pads and calipers from a 1979 3/4 ton Chevrolet 4x4.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    79 K20's had Corporate 10 bolts not D44's. I don't think the rotor is much different, but the calipers are and use different fittings (different diameter and/or length banjo bolts). So is it a D44 or 10 bolt caliper he wants? Asking because I would like to know too. Thanks
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    autozone part number for rotors is 5523 they run around $30.00 each, check out their website. they were the cheapest i found and made in the same place as those other more expensive places.
    ARQ.
