Question about flexxing with a 2 inch add a leaf,
Discussion in 'The Garage' started by Silver84k5, Nov 10, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    ok i put stock springs back in the rear of my blazer i love the way it rides now, although it still seems to sag a bit in the rear, (even after i took the 0 rates out of the front) so i was thinking of putting in a 2 inch add a leaf. How much flex difference will there be if i put in the add a leaf... will i even tell a difference? i can get my 39.5 far enough in the rear fender so i cant see the lugs of the tire, i would like to keep it that way TIA
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Anytime you add leaves to the spring pack, you're gonna affect the spring rate...how much is hard to say. From my experience, you will feel a difference.
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Flexxing is new to me, as i 8 inch springs before that didnt flex at all. Which will flex better 2 inch add a leaf or 2.5 inch springs?
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so what lift are you running and what kinds of springs?
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    4 inch front springs, and stock rear springs with a shackle flip and a 0 rate,
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so 5" already in the rear? adding another 1.5-2" would make the arse end higher. do you wheel alot with the top on? dunno. if you could find a 1" add a leaf, that might work. but it will lessen your flex if you are already running a stock pack.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    id rather have the ass end higher in the rear, cuz i still got a 0 rate for the front i can toss in there, i didnt even think they made 1 inch add a leafs, it would take some flex away, but not very much i would think, as for wheeling with the top on only in the summer it would be off, im just trying to figure out how much flex i would lose, i want to be able to stuff a tire in the rear fender all, the way up to the lugs on the tire... (not the lug nutz..)
  8. BlazinNewTrails
    BlazinNewTrails Registered Member
    Sep 20, 2002
    48
    washington state
    I'll pose this as a question rather than an answer because I am unsure if it's possible or rather... recomended.
    What if you stacked zero rates in the back?
    Put two 1" zero rates back there and your spring rate and flex should remain the same, add one back to the front if needed...
    Hopefully one of the guru's on here will tell you if this is ok or not!
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the way i understand it, the zero rate is incorperated into the spring pack. if you stacked two, it would then be at about 2" and, IMHO, axle wrap issues and normal "i am on blocks" behaviour would start cropping up.
    If anyone with expereince has anything to add i'm all /forums/images/graemlins/ears.gif
  10. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    thx for the idea but i dont think i wanna do that,
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Add-a-leaf != flex
    A 2 1/2 rear spring would flex better.
    I wouldn't stack the zero-rates. That would still be better than a regular block, but still I wouldn't do it. If you need more than 1" extra, do something other than the zero rate.
    -- Mike
  12. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    add a leaf's are made in different ways, some go on the bottom of the spring back (short style) and therefore have a higher spring rate to bend (lift) all the springs; other go under the main leaf or so (long style) and have a softer rate because they do not have to bend the other leafs
