question about gauges?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by IH82LUZ2FORDS, Nov 21, 2000.
  1. IH82LUZ2FORDS
    IH82LUZ2FORDS Registered Member
    Sep 25, 2000
    23
    Fargo, ND
    Hey, just this morning when I got up and started my truck and drove for about 20 minutes, I had noticed that my temp. guage hadn't moved at all, what could have caused this and what can I do to fix it, do I just need to replace the gauge or is there other stuff to it?
    Rob
    88k5
  2. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    Try checking your connections, you may just have a loose wire behind your gage.. it happens. BTW, I just figured out your username...THATS A GOOD ONE...
    http://www.rockosangel.coloradok5.com
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Could also be the wire coming off the block-mounted sender unit........mine did that all the time when off-roading due to the bouncing.........replaced the end and crimped it to stay on, problem went away. Make sure the wire going from it up to the gauge didn't hit your header/exhaust manifold and burn through too.......
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  4. Jackson 88K5
    Jackson 88K5 1/2 ton status
    Oct 27, 2000
    104
    Topsham, Maine, USA
    I would say the same the other guys have said check out the connection first before spending money. I like your user name. It took me a minute but figured it out, hey a little slow.
    http://www.tjcommons.com/88K5/
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Will it blow hot air? If not the thermostat is stuck open. Otherwise prob a loose connection...
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>Don't lose to any Turds and you won't have to hate it so much.........Just joshin'</font color=purple>
    <font color=purple>L8r,
    .Riz.<font color=purple>
  7. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    I would check the fuse, then all the connections first.
