Question About headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The85k5, Dec 16, 2001.
  1. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    well my smog is due in march for my 85 k5 and after it passes (hopefully) i'm gonna dump all the smog and through on a set of flowtech headers i have with dual 40 series delta flows....the main question is about the fitment of the headers. Anyone had problems with flowtechs? or didnt like them? i wanna get all the 411 before i screw something else up, also how can i get the best performance and sound out of these....H pipe and turndowns maybe? just a thought.
    Robb
    boy do 3:08's and 35's really SUCK
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I had Flo-Tech headers for a while. I had some problems with the collector hitting the front shackle on the passenger side. A big pry bar solved that problem, and I've heard it is a common problem on these trucks.
    One other area that I had numerous problems with was where the collector bolted to the header. I found that area was not 'flat' enough to provide a good seal and I constantly had collector leaks. Overall I wasn't especially happy with them and I recently swapped an older set of Mr Gasket headers on. I haven't had a leak anywhere with the Mr Gasket headers.
    The Flo-Tech's were real good in one area...spark plug access was awesome.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I think no matter what header you think about getting, there will always be someone that has had a bad experience with them. You could spend $90 for a set of dynomax headers and have no trouble with them and someone could soend $300 for some hooker super comps and have nothing but trouble. Mistakes will always be made in manufactuing.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I've got ceramic coated Super Comps on my BBC, and they are great. There are some interferrence issues with the frame rails... IE the headers make light contact with the frame if the engine is really getting knocked around...
    Other than that - they are great... [​IMG] But for $480 they best be really good...
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  5. The85k5
    Feb 22, 2001
    259
    Sunnyvale,Ca
    yea i'm probebly gonna just stick with the headers i have....i got em brand new in the box for 40 bucks so i couldnt really beat that deal but i'll have to look out for then hitting the shackles....i can see how that could be a problem!
    thanx again
  6. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    To help seal the headers, try putting a light coat of Permatex Ultra Copper silicone gasket sealer (do not use the generic brands, they do not last) on the gaskets (engine &amp; collector) when you install them. It will hold up to the heat &amp; virtually stops all leaks. I now do this on all header installs &amp; haven't had a leak since.
    Lonnie
