Question about installing a spool
Discussion in 'The Garage' started by odoa3, Jul 12, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I decided to go with a friend's recommendation and go with a spool for a 14 bolt ff and had a question. The spool competely replaces the carrier, correct? A guy up here wants to buy my carrier and just wanted to make sure I didn't need anything before I sold it to him. Thanks.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They make some spools for 14 bolts to fit in open carriers , like this :
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I just installed that one on saturday very easy install did it in about 30 minutes.
    I used this write up I found over on pirate http://www.pirate4x4.com/forum/showthread.php?t=328610
    anyways, yeah the mini spool replaces the spider gears or you can get the full spool.
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    I am going with the full spool. Only time it is on the road is on the way to the trail.
  5. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I don't mean to take away from this post but what exactly is a spool. Is it comparable to a locker?
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    A spool gives you the same effect as welding the spiders, 100% locked up all the time. Great for wheeling, sucks for street driving.
  7. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    cool thanks...is there any drawbacks to going a the spool over say a detroit for an offroad only rig.
  8. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    The picture above is for a mini spool. That unit you need the carrier for as it just replaces the spider gears.
    A full spool would in fact replace the carrier. I haven't looked too deeply, but I've yet to find a full spool for a 14bff.
    a spool will be "engaged all the time. I like them because they're more predictable. A locker can unlock at any time. I have a friend that has a mini-spool in his bronco 9in. I've actually never heard him chirp tires on the street when I've been with him.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yukon sells a full spool for 14FF. But most of their parts are backordered right now...
  10. bajaviking
    Apr 10, 2002
    752
    Baja
    If it's for an offroad rig only I would get the spool or just weld the spiders into a big ball and be done with it. Cheap and affective.
  11. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thanks for the info guys. Now I've got something new to think about for the project truck.
  12. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Randy's Ring and Pinion has the full spools for the 14 bolts. Give them a call, great customer service, easy to talk to and answered all the stupid questions I could come up with.
