Question about kick down on Turbo 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Sep 1, 2004.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I have a 74 K2500 with a 350 and Turbo 350 trans. The guy I bought it from swapped carbs and there really isn't a way to hook up the kick down cable. This is just a beater daily driver and I don't care too much about it actually "kicking down", but, if the cable isn't hooked up can it cause any damage to the trans?
    Thank,
    Eric M.
  2. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    It will not hurt anything, but it is going to be a frustrating experience driving that truck without a detent cable. Go to a junkyard and see if you can find the proper throttle bracket for it that has the detent cable connection on it.
  3. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    I've got the stock bracket, it's the after market carb. the guy put on that won't work with the cable. If it doesn't hurt the trans., it's not an issue. I'll eventually be parting this truck out so I don't want to spent too much time or $$ on it, I just don't want to burn up the trans. which was rebuilt 10K miles ago.
    Thanks,
    Eric M.
  4. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    What kind of carb is it?
    You can purchace an adapter for both Edelbrock and Holley carbs.
  5. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    I didn't even think about that. It's an Edelbrock. I'll take a look at the Summit site and see what they have. That sounds like a cheap and easy fix.
    Thanks,
    Eric M.
  6. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Whenever I replaced my q jet with the Edelcrap I hooked my kick down cable around where the throttle cable hooks up too. Just got a longer bolt, used some nuts and washers to space them apart and BAM your kickdown cable is back in operation.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Since nobody has mentioned it, I will.
    TH 350's upshifting is controlled by the vacuum modulator and it won't hurt anything to not hook up the detent/kickdown cable.
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    This guy has done some funky stuff. It's going to take more than that to get this set up to work! I ordered up a bracket set from Summit today. $31 with shipping. It looks like what I need. I'll post up when it arrives.
    Eric M.
