question about making D60 steering arms
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, May 24, 2001.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I have a piece of steel 12" x 12" x 1". I was thinking of trying to make a steering arm for a dana 60 crossover steering and save myself a $150. And if it works well, I think I have enough material for two more. Does anyone have some really good pictures of one? Preferably next to a ruler, and from a couple different angles.
    That's because I'm the devil.
  2. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    man, sounds like you shouldnt be attempting to make one if you dont know where to start. i made one for my d44 but i did it on a milling machine.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    BTW, is'nt the metal used for those steering components made of some stronger type of steel? You can't just use regular mild steel that is readily available at most welding shops. My guess this part would need to be a high-tensile steel part.
    When In Doubt, Whip It Out!
  4. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Hi,
    I'v been thinking the same thing. Offroad.com chevy section x-over has some good pix. next to a ruler even. The metal isn't any thing fancy. I have two on the 10 bolt x-over, tie-rod over set up. they dent pretty easy. I also had to grind some clearence for the ball joint top lip. It didn't take long to do, thats to say it didn't "feel" like harder stuff dose when you grind it.
    Hope this helps
    Russ V
  5. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Hey, thanks a lot. Those are some good pictures.
  6. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Yeah, I'll check with the guy I got it from. I'm pretty sure it's good quality because he knew what I wanted it for, but I wouldn't want it to bend or worse on me while I'm driving.
  7. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I made my own Dana 60 steering arm with cap and I could make anyone else one at a very reasonable price. Just email me if your interested. I work in a machine shop and cut metal every day. The steering arms you buy from these companies are just regular steel. I've also made Dana 44 arms and milled the knuckle flat for a friend of mine with a YJ. I'll try to get pictures of them up on the web page.
    charles.h.babcock@intel.com
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 38" TSL's on steel wheels
    <A target="_blank" HREF=http://www.azk5.coloradok5.com>http://www.azk5.coloradok5.com</A>
