Question about my Dad's 95 Monte
Discussion in 'Other Rides' started by 85blazerk5, Mar 6, 2005.
  1. 85blazerk5
    85blazerk5 Registered Member
    May 30, 2004
    75
    WV
    I am stuck with a big problem here....My Dad's 95 Monte will run fine for 2 weeks or so, then it just won't start. We have had it to every shop around here and it acts fine for them. It will turn over when it tries to start, but it just seems to flood out. Thank in advance if anyone has had this same problem.
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    my sister was flooding hers by hitting the accelerator pedal and then turning the key on. also you should be able to pull the codes off the computer and see what's going on.
  3. 85blazerk5
    May 30, 2004
    75
    WV
    pull the codes off of what computer? The one at the shop or what? Or is there codes in the book that say what's going on?
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Does it do it when it is cold or after it is warmed up?
  5. 85blazerk5
    May 30, 2004
    75
    WV
    It does it both, he can drive it for a while and then it won't start, then he will let it sit for a couple hours and it will start. But then the next day or so, it won't start.
  6. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like it may be a coil pack issue. The coil pack is the thing that all the plug wire go to. Thay canl cause starting problems when they start going bad.
    Have you checked for trouble codes? Check for trouble codes before replacing anything. Some Auto parts stores like auto zone will do a scan for free
    Post the results. .
  7. 85blazerk5
    May 30, 2004
    75
    WV
    I will see if I can get it over to auto zone and see if they will hook it up. Thanks for the advice.
