question about paint jobs
Discussion in 'The Body Shop' started by kotton, Sep 2, 2005.
  1. kotton
    kotton Registered Member
    Sep 1, 2004
    64
    Orange County, California
    I have no experience with paint shops so maybe you guys can help me out. My girlfriends car has started peeling the clearcoat in a lot of places. Is it possible to have some shop wetsand the clearcoat of and just respray another one on, or will they have to take all the paint off and redo everything.
    thanks
  2. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    it wont need to be stripped.. but they will usually need to throw a couple coats of basecoat on, before reclearing... you can't usually just reclear it...
    the minimum will usually be wetsand featheredging the bad spots then some base, then clear.. most shops will strip the clear to the basecoat, couple coats of base and clear..
  3. kotton
    Sep 1, 2004
    64
    do you think i could get away with doing this somewhere cheap like macco since they dont need to re prep and primer it, since i heard that is their weakspot.
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    when it comes to paint job YOU GET WHAT YOU PAY FOR:D
  5. kotton
    Sep 1, 2004
    64
    thats not what i wanted ot hear :mad: but its true
  6. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    honestly, i wouldn't.. little bit on the "technical" side for them...
    there are a few variables here... the sanding... if you go for just a feathering of the peeled areas, it is generally safer to spot prime that area. the reason being to seal up that feather edge between base and clear.. that is a trouble area. the reason being the reducers in the base your applying to the area will want to lift and cringe that edge.. it can be done, you just need to be aware of it when applying basecoat.. if you prime those areas, it eliminates that issue...
    and i wouldn't really want them stripping the clear either.. have to know what your looking at when prepping that way.. the prep of a job like this critical, ie sanding... even when knowing what to look for, sometimes a spot or 2 of primer is recommended..
    you could stop by and talk to em armed with that knowledge and see what they have to say... some of the stories i've heard about them have been scary.. i come from a resto shop and highend collision shop so i really hate to see corners cut.... maybe if you sanded it and brought it to them...
