question about pinion angles when doing a 4" shackle flip
Discussion in 'OffRoad Design' started by BlueKnight, Apr 6, 2002.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    question about pinion angles when doing a 4\" shackle flip
    Hey Stephen I work at 4 wheel parts and well im debating on going with a 4" shackle flip with you but some dicussion came up about extreme pinion angles when doing a shackle flip. How bad of an nagle does it put your driveline at also with a shackle flip are we looking a lengthened drive line?
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Re: question about pinion angles when doing a 4\" shackle flip
    I have the 4'' shackle flip with 1 1/2'' blocks and the pinion angle is within 4 degrees of the driveline, without the blocks it was within 2 degrees wich is where I wanted it to be. I have an NP208 and with the 5 1/2'' the slipyoke was pulled out 1/4'' further than the factory had it after I lowered the T-case 1''. So the problem was never with the driveline length, but the angle in relation to the T-case. With my 5 1/2'' I could benefit from a c/v shaft, but if you intend to just go with the 4'', it will work fine if you lower the T-case 1''.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Most of the time a 4" flip will point the pinion near the driveshaft which is perfect for a CV shaft. If you want to try a ujointed shaft, you will likely need to shim it down some. It can vary a few degrees just with a small height difference in the springs, we set a guy up with some zero rates not too long back that recorded a 5 degree pinion angle change with a 1" ride height change! So it's no wonder trucks act so much like individuals.
    Driveshaft length is generally fine with the flip, you can typically use the stock shaft with no problems.
    Hope this helps
