Question about plastic...
Discussion in 'The Garage' started by Jeff427, Jul 8, 2002.
  1. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    or teflon friction pads on the ends of the leaf springs. I got a nice set of leafs for my 77 K5, but I need new "friction reducing pads"(for lack of knowing the technical term /forums/images/icons/crazy.gif ). Where do I get replacements for cheap? Or if any one has a decent set laying around that you aren't going to use, let me know, I will swap stickers for them /forums/images/icons/grin.gif.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Should be able to get them from National Spring or any spring shop. </font color>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, any spring shop should be able to set you up with the anti-friction pads. But they won't be made of Teflon. Teflon is a pretty soft plastic, that "cold flows" under pressure. It will literally deform and squeeze itself right out of a high pressure situation.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yeah, I think that the better ones will generally be made of Delrin, but that's kind of a guess... </font color>
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The slip pads are made of UHMV urethane or something (jekbrown know's the exact name... /forums/images/icons/crazy.gif )
    I just priced them out at a local spring shop for my buddy's 89 Blazer springs. I was quoted 47 cents each... /forums/images/icons/grin.gif These are the factory replacement pads and require the oval hole at the end of the spring to clip to.
    Rene
  6. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    47¢ each Canadian? So that is like 15¢ each US, then right Rene /forums/images/icons/wink.gif? J/K /forums/images/icons/grin.gif. Yes the springs I have, have the oval holes in the ends. Ultra High Molecular Weight Polyethelene is what you mean, right /forums/images/icons/shocked.gif?
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    That would be the stuff... /forums/images/icons/grin.gif prolly 16 cents US though. /forums/images/icons/smirk.gif
    Rene
  8. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Another option for your purchase is your local Dodge dealer. There is a TSB (tech. service bulletin) out for the Durango's and Dakota's. They have an issue with the springs making a clicking noise. The fix is new spring tip pads along with a few other peices. There is even some cool lube for them. Anyway... you can buy these there. They require a hole in the spring tip to mount. Since im not at work right now I dont know the part #. But this is a common problem and all dealers will have them in stock to sell.
  9. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    Hey Tori, cool sig /forums/images/icons/grin.gif. If you get a chance, I would appreciate it if you could post up the part no. for those. My local Do*g* dealership is the crappiest place on earth to buy parts from. But I would like to get them ASAP, so if they have them in stock, it might be my only option for getting them quickly. Thanks /forums/images/icons/smile.gif.
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    gah, go to a plastic supplier and get some UHMWPE (translation: ultra high molecular weight poly ethylene). This stuff does NOT cold flood, greatly reduces friction between leafs and just plain works. Check out my web shots, I post pics in my shackle flip gallery where I show how I used UHMWPE in my rear springs.
    J
  11. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What was the exact length and width you ordered, and how much was it?
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I think I got around 22-24'... and I did both my rear springs with that much and had a few feet left over. Of course this would change depending on the # of leaves and the length of your springs. It comes standard on 3" wide rolls... which you can trim down with good scissors to 2.5 or 2.75 or whatever. I forget the exact cost... its been 8 months since I bought it... I'm thinking around $1.5/ft.
    J
  13. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    Jekbrown, what keeps the UHMW from working out from between the leafs? I am sure that setup will work great, I'm just not sure how to keep it in there /forums/images/icons/confused.gif.
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    About time someone found a good use for plastic.....hate seeing the stuff on car bumpers and doors, etc.
