question about poly kit, spacers and washers but no bolts
Discussion in 'The Garage' started by jjlaughner, Nov 19, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I just got my poly body bushings from 4wheel parts all the bushings are there, washers, spacers but there are no bolts /forums/images/graemlins/confused.gif
    Do you only get bolts with a body lift?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i didnt get bolts w/ my poly bushings. But it did get bolts w/ body lift.
  3. dyeager535
    26,982
    191
    Didn't get bolts with my energy suspension kit either.
    If you got an energy suspension kit, ignore the part about using nuts on the back of the rear bumper braces. You'll never get your bumper brackets off without dropping the tanks if you follow their instructions. Modify the stock bracket.
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Other than the axle there is nothing under my truck right now, as a matter a fact there is nothing except the fiberglass top above the axle either /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You get new bolts with a body lift because you can't install the body lift with the original bolts. They're too short. /forums/images/graemlins/wink.gif
    You can reuse the standard bolts with the poly bushing kit. (But I'm betting that yours are VERY rusty). /forums/images/graemlins/eek.gif You'll probably need to buy new bolts. Galvanized ones would be best there in the salt belt. /forums/images/graemlins/wink.gif
