Question About Stock Drive Flanges (slugs) In A D60
Discussion in 'The Garage' started by Resurrection_Joe, Oct 6, 2003.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I just got my D60 in and it didn't have any hubs on it, but came witht he drive flanges. All I could find were the caps and the slug itself. So my questions are as follows
    1. Which was do the slugs go in, I had them in both ways, with the flat face facing out, or with the small protruding stub thing facing out?
    2. I currently have them witht he smooth flat face facing out. If this is wrong, how the hell do I get them out? Drill two tiny holes and use screws like on a locking hub?
    3. Shouldn't I have a snap ring or something else to keep the slugs from popping out?
    4. Should I be packing these things with grease when I install them?
    5. Are the cover/caps just press on?
    Thanks!
  2. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    *COUGH COUGH COUGH*
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Ok,
    I don't own a D60, but i'll give it a try.
    1. The small prutruding part goes out.
    2. Hit the axle shaft with a hammer lightly and it jars the slug loose. Pliers on the small sticking out part to pull on it.
    3. Snapring=YES !
    4. Not really, but you can if you want. As long as the stuff behind them has grease.
    5. Covers just presses on. You can use a little RTV to seal the grease in and water out.
  4. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Hmmm ok then... where do I get the snap rings ?
  5. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Hardware stores..... I don't know the size. Just measure and buy that size plus the one above and below it.
    Blake
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Someone want to verify the way these things go in? I can't find anything anywhere, Pirate, CK5, ORC, MOO, nothing !
  7. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    My Dana 60 parts manual shows them as follows. The spacer goes in first, then the Gear with the small, shouldered portion facing out. Then the snap ring. The Dana part number or the snap ring of a 30 spline outer shaft is 37330. Then the cap goes on.
  8. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Oooh, thanks a lot!
    Looks like I'm missing the spacer.... oops
    By chance do you have the number for that?
  9. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I've only installed the Warn Drive Flanges and they had the slug go in but with a few spacers behind it then it had a snap ring on the groove on the stub shaft then the big snap ring on the hub that held the slug in place. Then it had the cover which was held on with 3 cap screws. Never dealt with stock style ones...
  10. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    Sorry, no part number listed for the spacer. My diagram also shows a pressure spring for another application instead of the spacer. But, no part number for it either.
  11. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I installed my broached out, D60 drive gears using D44 drive gear springs as spacers...worked great!
  12. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Any idea where to get those then?
    Thanks...
  13. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Bone-yards.
    Remember to check Furds and Jeep vehicles for full time D44s.
