Question about tcase
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by InSearchofAk5, Jul 17, 2001.
  1. InSearchofAk5
    InSearchofAk5 Registered Member
    Jul 16, 2001
    35
    In the ck5 specifications page i read the 79 blazers have an NP203... correct me if im wrong... but i read in a 4wheel mag that the np203 is fulltime 4wd. Thats not right is it? Thanks
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    that is right but there are kits to change it over to a part time.
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I believe the NP203 is fulltime (unless converted) you may be thinking of the NP208 which is part-time.
    If you didn't build it yourself, how can you call it yours.......?
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, but the 208 wasn't available until 1981.
    Anybody planning on checking out my homepage, forget it, I am still working on it!!!
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    If you have a manuel tranny then it would be a 205 and it is part time.
    I thought I was wrong once,
    but I was mistaken
  6. InSearchofAk5
    Jul 16, 2001
    35
    Right ... i guess that guy got a conversion. He said that he got the 4wd adjusted so that it slips into 4 easily... i dunno.
  7. jshadwick
    jshadwick Registered Member
    Jun 24, 2001
    45
    Sacramento, CA
    203 is for the automatic, full time, 205 for the manual tranny,part time, which is what i have in my '79.BTW, what or where did you hear about this guy having his "adjusted"?
    james
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I've never done it myself, but you can adjust the shifter linkage on a NP203 so that it shifts easier and doesn't pop out of Loc mode. I think there's a grease zit somewhere over there too, but not sure. (Who could grease it anyway?)
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  9. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    You can adust the linkage. If you have a haynes it show the procedure in there. You basically put a drill in the hole at the side of the shifter box in the neutral position. I cleaned my shifter it was full of rust. I greased it after I did not see any grease fittings though.
    Lukers
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  10. InSearchofAk5
    Jul 16, 2001
    35
    When i called the guy he was like "i got the 4wheel drive adjusted so that it slips in real easily"
    So I don't know what that means. If it's fulltime why does it have to slip into 4wheel? Or maybe He has a new tcase? He has had many other parts replaced...
