question about the 6 lug to 8 lug conversion
Discussion in 'The Garage' started by scrappyk5, Oct 2, 2003.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have read all the info on this , but need to know
    two things. if i have a 1984 k5 with the 10 bolt ,
    will i need to change my spindle and bearings ?
    or do i just have to get the rotors , calipers,and
    backing plates ?
    /forums/images/graemlins/confused.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Most of the time the spindles are the same... but you will have to change from the backing plates out
  3. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    On my 88 I just had to swap my backing plates and rotors...calipers were the same
    pretty sure thats all you would need too
    Later
  4. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    so the rotor/hub combo will slide right on my spindles.
    cool .
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    As long as you get a '77-87(91) donor with the same style lockouts you have now, then yes that is correct /forums/images/graemlins/thumb.gif
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Bearings may be different, but I don't know for sure on your application. I know on my small bearing design Dana 44 the inner bearings were different, outer bearings were the same. Both used the same spindle, and as said before different backing plates, rotors/hubs and same brake caliper. /forums/images/graemlins/thumb.gif
