question about the front drive-shaft
Discussion in 'The Garage' started by justwhatido, Jul 20, 2005.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    There is a velocity joint (double u-joint) arrangement with a very small diameter shaft connecting the front drive-shaft to the front differential.
    Can the front driveshaft from a later K-5 be used. Seems like there should be a heftier through piece than what's on my 1973.
    What are my options?
    Fred
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The 73 uses a Spicer style driveshaft (yoke on transfer case). Later ones (~1978) use a Saginaw style driveshaft (flange on transfer case). These later ones use a S44 (roughly the size of a 1330) joint in the double cardan part as compared to your 1310 shaft. I believe the splines are the same.
    You could have a Jeep front driveshaft on your 73. I've seen people do this before. The splines are much smaller.
