question about the pain level
Discussion in 'The Garage' started by grunt11b40x, Oct 6, 2003.
  1. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    scale of 1-10 the level of pain to remove the tranny while the xfer case is still mounted in the blazer? th350-np203 set-up. has anyone done this before or is this a pipedream? /forums/images/graemlins/thinking.gif
  2. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i misread the post
    ok
    i have drop a 700r and 208 a few time the only PITA is the hight of the trany i need blocks on the jack for hight and remove the jack and slide it out on the pan it is a 8
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Considering the weight of a 203, I'd make it a 9 unless you have a tranny jack.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I did this couple weks ago. I used two floor jacks and a friend. Pretty painless just have to go slow. I did it on dirt and it took a couple hours. Hardest part is reachin the damn bolts.. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif I'll give it a 5.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if its not going back in, use some wood to get the jack up under the setup, take all the bolts out, disconnect all the shifters/linkages, drop the jack and let it fall...but since i figure its going back in, use a couple ratchet straps to hold it to the jack...and take your time..
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    HELLO
    unless i am totally crazy ( very possible :-) the way it reads to me
    this guy wants to leave his t case there and only remove the tranny
    {to remove the tranny while the xfer case is still mounted in the blazer? th350-np203 set-up}
    (IF) that is the case PIPE DREAM as we all know in the 350 - 203 set up the out put shaft from the tranny goes directly into the t case so you must remove both at same time OR t case first with or with out adapter then tranny
    i find it easyer 2 do em both at the same time
    and il give it a a 6 if your AT LEAST A 1/2 AZ DECENT MECH.
    if your not then easly a 8 + mabe even a 9
    on a 1 - 10 scale were 10 is the most difficult
    best of luck
    R
  7. grunt11b40x
    Mar 1, 2003
    124
    winston salem, nc
    lol thanks for the info guys, guess I am in for a long nite and a lot of empty beer bottles. /forums/images/graemlins/k5.gif
  8. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    if you have an engine hoist its supereasy...remove the trans
    tunnel..run the hoist in the cab..and drop the tranny..i had to do the same, when the flexplate broke...took me about 2hrs...also depends on your mech. appitude..pain scale
    5+
    all hail the almighty sawzall
    twisting driveshafts since 00
