Question about tire size on stock rims
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PGL4VT, Nov 17, 2002.
  1. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    From what I know, two different rims came on late K-5's...the old 15x8 rally and the polished mag which is a 15x7. Correct? Question (and I know this is whimpy compared to most of you guys) but I ran across a very lightly used set of 32x11.50 Dunlop Mud Rovers and I'm not sure I should mount them on the 7" rim. Dunlop says it recommends them on a minimum of an 8" rim. What do you guys think? /forums/images/graemlins/ears.gif
  2. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    i think you should go for it. cuss people run a 12.50 tire on a 8 inch rim. and it has worked out for them. so i say go for it. later.
    jacob
  3. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I'm running 32"x11.5" on my truck till I go 1 ton then it's 35"
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Yes, you can do it. It will force the center of the tire to stick up, causing it to wear faster, but hey, I got 50K miles on my tires. 12.50 tires are stuck on 7" rims all the time.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have run 35x12.50x15 tires on a 7" rim, I just run them at a lower pressure so they don't wear out in the center.
    Actually it's better for bead retention, no nead for bead locks. /forums/images/graemlins/thumb.gif
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you can run 44x18.5 Boggers on 8.25" rims. so i think the 12.5 section width would be fine. adjust air pressure appropriately.
  7. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i'm running 38.5x11 /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gifboggers on factory 8-lug 16x6.5 no prob
