question about tires and wheels
Discussion in 'The Garage' started by wilsowe, Jan 11, 2007.
  1. wilsowe
    wilsowe Registered Member
    Nov 28, 2006
    26
    Auburn, Alabama
    I've got a hookup on some 33x12.50x15 procomp xterrains mounted on 15x10 steelies with 3.75 inch backspacing. Do ya'll think this will fit on a stock 1990 k5? Also, if the wheel are too wide or wrong backspace, what about the 33x12.50 on the stock 15x7 wheels, would that work? Thanks for any and all help.
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Yes and yes :D !
  3. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
    I don't know for sure if the backspacing will be OK, I'm thinking it should, but 33x12.50R15s on 15x7s doesn't seem like a good idea, too much tire and not enough rim...:thinking:
  4. wilsowe
    Nov 28, 2006
    26
    Auburn, Alabama
    Okay, so we've got a yes/yes and a maybe/maybe so I guess I'll give it a shot.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    :confused:
  6. sandawgk5
    Oct 28, 2003
    6,881
    I run 12.50s on an 8 inch rim and have no problems I say go for it. What is 1/2" difference ya know:D . I plan on running 42X15X15 on these same 8" rims also maybe a 42X15X16.5 on H1s so I do not subscribe to the too much tire / too narrow rim crowd.
    Ira
  7. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    what is the disadvantage of "too" narrow of a rim anyways??
    (sorry for the hijack)
  8. spent21
    spent21 Newbie
    Oct 18, 2006
    Nashville, Tn
    i run 33 x 12.50's on 15x10" rims with a 4 inch lift and recently noticed that i have bent the rear lip of the front fender. i have seen 32's on a stock blazer and that looks like as much as i would run with no lift and no trimming.
    wide tires on a narrow rim will have more of a roll in the turns, kind of a 'flat tire' feel.
  9. Craig Artzner
    Dec 16, 2006
    6,843
    Northeast Ohio
    Back in my younger days (1998) I had a '75 Blazer and had 31x10.50R15s on the stock steel 15x6s and I noticed handling difference (a negative one). It wasn't a HUGE problem but I definitely noticed a difference. I upgraded to 15x8s as soon as I had the money to do so.
    I'm just putting this together, 33x12.50R15s on 15x7s? He's gonna notice a diminishing effect on the handling. Some people don't mind that, though.
    Just my 2 cents.
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    There is really no reason you should be able to notice any handling differences between something like a 7" and 8" rim assuming you have the same tire.
    33x12.50s on a 15x10 rim will fit on most stock K5's, though they all differ a little because of spring sag, etc... However it will definitely be tight and would probably only be okay on the road. Any flexing off-road would likely cause the tires to hit the fenders. Put the same tires on the stock 15x7's and you would have more room. The wider rims will put the tires closer to the bottom edges of the fenders when you turn them.
  11. goldwing2000
    goldwing2000 Guest
    It causes the tire to "balloon" and look like a ring bologna, which will wear out the center of the tread prematurely. On the plus side, it helps if you rock crawl because you can run seriously low tire pressures without rolling off the bead.
    wilsowe: the wheel size and backspacing will fit fine. It may rub the fenders a bit when the tires stuff up but hey... that's why they invented lift kits, right? :D
  12. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    Thanks man, that clears things up for me.
  13. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    ive got 15x10s and 33x12.5s and the scrub while flexing and turning/flexing, both on the front. ive run 30x11.5s on a 15x6 before. sideways buldged like heck but i wont worried about poppin a bead. hell it was a b*tch to get tires unmounted to sell them.
