question about tuffcountry 4" lift
Discussion in 'The Garage' started by BL1TZKRIEG, Jan 6, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    Hi, I bought a 4" tuffcountry lift , springs in the front, blocks in the rear,for a 90 fullsize blazer. I was wondering if I would have any driveline problems.
    will the stock drivelines be ok with that angle or do I need new ones,will it chew up my u-joints? It will mostly be just a daily driver. any help would be much appreciated :)
    by the way great site you guys got here :waytogo:
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've been running a 4" lift on my '90 K5 since around '95 with the stock shafts front and rear. When it was a daily driver I had to change the joints in the rear shaft every year or two.
  3. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    just did the exact same lift on my 90 blazer this past summer. You will need to do the following.
    drop transfer case using stock spacers. go between crossmember and frame.
    you will need a drop pitman arm not a raised steering arm. (skyjacker pt # ca-90)
    longer front brake lines. use 88 chevy 1/2 ton fronts
    rear brake line is napa part (search to find) misplaced my reciept for it
    I have been driving mine daily and it is very streetable and rides better than it did w/ stock setup.
  4. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    thanks a lot for the help
  5. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    ummmm....
    Ummmmm.. Careful with doing this. Using the spacers on the wrong side of the frame can cause your frame to break. I've seen it before and it sucks bad. For street only use, it would probably be okay to do this. But, if you plan on taking it off road, you frame will probably break where the bolts are located.
    Jut letting ya know.
  6. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    any other suggestions?
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am running 4" TC springs in the front and 6" TC springs in the rear (minus 1 leaf to lower them to 4") My truck is basically at the max of what stock drivelines can survive at. My tcase is dropped down about 3/4".
    I had to add a limiting strap setup to the rear axle droop so it didn't bind the rear driveshaft. If it wasn't there and I got in a situation offroad where both rear tires were allowed to go to max droop the driveshaft would break.
    Harley
  8. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    oh I forgot to mention my kit came with 5.5" blocks for the rear is that normal?:confused:
  9. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    hey did u ever get ur kit installed?
    i installed mine i got the 5.5" block im swaping it out for a 4" block
    i had some bad vibes at 0-30 and a grinding noise too
  10. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    yah I got it installed but my driveline angle was to severe so I ditched them and got a 4" shackle flip
    I had nothing but trouble with the 5.5 block
    It was just to much angle
  11. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    welli ordered 4" blocks now and if it vibrates ill prolly drop the tcase
