Question about using larger 9/16-inch diameter grade-8 U-Bolts...
Discussion in 'The Garage' started by 1-ton, Jun 3, 2005.
  1. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I am going to install a set of ORD zero rates on the front of one of my 1991 V3500 (Dana 60), but I need to get a set of longer U-Bolts.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    My U-bolts are 5/8" factory. I'm pretty sure every K5, K10, K20, K30 used 5/8" diameter U-bolts from the factory. :confused:
  3. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    Maybe I have some of my specifications wrong. Feel free to enlighten me with any information anybody has. I got most of the specifications off of RockStomper's web site. I will call them on Monday for the "skinny", but for now it is the weekend, and I thought I would just post up some questions on the project until then.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    One other thing, if i'm not mistaken ALL U-bolts are grade 8 as well as ALL allen bolts are grade 8.
  5. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    this is directly off of RockStompers web site.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Do yourself a favor and go measure the diameter of your existing U-bolts and that will answer your own question. Maybe rockstomper is incorrect on what they are saying. I have swapped many axles front and rear and they were all 5/8" diameter. I think the real early D44 used 9/16" diameter.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    every U bolt on my truck is 5/8" and they are the same size as the factory ubolts, just longer. i would not run anything less then 5/8"
  8. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I think the problem we are having here is you guys are talking about "nut" diameters, and RockStomper is talking about the actual "bolt" diameters.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im talking about the bolt diameters, i think the nut diameters are 7/8" on the 5/8" ubolts, maybe its 13/16"
    you gotta remember, rockstomper and alot of the other places deal with smaller trucks (jeeps, toys, samaris, etc) and to them a 1/2" ubolt is standard. so when they say upgrade to our 9/16" bolts, you may wanna check what you have before you buy them.
  10. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    no not all ubolts are grd 8. up to 9/16 thay are grd 5 then it goes grd 8 . i use to work at a spring shop and we use to up them all the time to grd 8 .:cool1:
  11. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    shoot the Nuts on my u-bolts are 15/16 :blush:
  12. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Yeah, my factory and replacement u-bolt nuts are 15/16" and the u-bolts themselves are 5/8".
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    My U-bolts are 5/8" fine thread. Nut size is 15/16" and they came with the double tall nuts and hardened flat washers.
    Rene
  14. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    same here...
    Every GM truck I ever fooled with had 5/8" U-bolts and 15/16" hex on the nut size...stock factory ones anyway.. :crazy: ...
  15. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I got out my Venier Calipers, and measured my Dana-60 U-Bolt diameter. It definitely came out to .625 thousands of an inch, which equals 5/8. I just assumed that because RockStomper only seems to deal with Dana Corp stuff that the U-Bolts dimensions they where talking about pertained to Dana differentials. I will call them on Monday to get what I need.
  16. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    My next question is where do you measure the length on a U-Bolt? I am assuming it is the straight part from where the U-Bolt bend ends up to the end of the threads. I am measuring approximately 7" using these measuring points, with an extra 1" of thread sticking out of the top of the U-Bolt plate. My guess is that I need an 8" long U-bolt to install the Zero Rates.
  17. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    You measure from where the bottom of the axle tube meets the U-bolt to the end of the threads.
    I believe Superlift #3418 is what you're looking for. It comes with longer studs. It should be plenty long but I'd call to ask. The 1/2 ton front kits I've bought are long enough for a pack 3.5" thick.
  18. sweetk30
    Nov 1, 2004
    25,539
    538
    yes tat is correct. but also measure the tube or the spread of the ubolt about where it rides on the axle tube. this will get you the width to go with the length. and if you want to help them out take 2x the length and add the width and this is the length rod you need. like 9" leg and 3" tube would bee 9x2+3=21" rod. but the rod only comes in even length so 22" rod. and when you bend ubolts round bends strech just a bit. square shrink just a bit. hope this helped you.:D
  19. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    Thanx. I ordered that kit today from Summit Racing. After doing a lot of research on SuperLift's web site application catalog, I still cannot find the specifications for U-Bolt kit #3418, but Summit Racing is not going to ship the kit out until the 19th of June, so I have plenty of time to cancel the order, if I cannot get the specifications from SuperLift. As long as the U-Bolt length is 12"...it will work.
  20. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    That is interesting formula. It is kind of like straightening out the U-Bolt, and measuring it's entire length.
