Question about warning lights on 92 Sub
Discussion in 'The Garage' started by TylerT, Sep 13, 2005.
  1. TylerT
    TylerT Registered Member
    May 30, 2005
    40
    OKC
    I just bought a 92 Suburban, and I've got a couple of warning lights on the dash. 1 is the E-brake light, it says it's on, but it's not. The other is the ABS brakelight warning light. Anybody have any idea why these 2 would pop up together, out of nowhere? Thanks
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    e-brake not adjusted correctly
    e-brake switch broken
    Brake fluid level low
    ABS probably has a fault, you need to get it checked. The light being on means only the ABS part is not working. You have standard brakes now that can lock up. Don't worry, ABS being off isn't gonna lock your brakes for no reason, you'r just back to normal brakes with no ABS assistance.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The ABS system has detected a fault. When the ABS light comes on (at least in trucks of that era) the red "Brake" light also comes on. It's probably some legal stuff for people that are just too freakin' stupid to realize that the ABS light has to do with the brakes, so those morons can't say they were in a wreck because they "didn't know" that the ABS light meant "brakes"... :doah:
