question aout towing?
Discussion in 'The Garage' started by chevyman562, Nov 15, 2004.
  1. chevyman562
    chevyman562 Registered Member
    Feb 2, 2003
    46
    The lovely LBC
    Can a short bed 1/2 ton shortbed pickup fitted with 3/4 ton axles and a 454 tow as much as a stock 3/4 lonbed pickup with the same options? I would much rather have a short bed, but am looking at having to tow a 19 ft trailer every so ofton.
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    the added wheelbase of a longbed always helps to control the trailer while driving. What may also matter is the weight of the trailer, the heavier it is the more you will want a bigger truck. Also, what kind of brakes on the trailer? (single axle or double) There are a lot dicussions of this type in the tow/trailer forum... i would suggest you look around there
    also a couple other items that would need upgrading:
    Rear Springs and Brake Booster
  3. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    You will have more control over a longbed truck due to the fact that the weight will be distributed better on the truck and there will be more weight over the front wheels than a shortbox.
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I pulled my brothers short bed K10 160 mi. last week with my K10. I didnt have any problems. The BB didnt miss a beat and got about 9 mpg. I have a 454, sm465, 3.73s and 4 wheel disc brakes. I would suggest having trailer brakes though. If you have to stop fast it could get scary. I do plan to put some heavier springs in the rear to help carry the load better. If you run an automatic be sure to put a big cooler on it, heat can kill a tranny real quick. A long bed would be better and safer, but a short bed would probably get the job done as long as you are careful.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    #1 no
    #2 a 19' trailer is nothing, I wouldn't worry about it. Go for it.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    #1 no
    Agreed, you will never be able to match a long bed's towing capabilities because you can't make up wheel base with a bigger engine or rear end.
    A 19' trailer isn't bad as long as it isn't too heavy.
