question for 80's blazers with mechanical clutches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, May 3, 2003.
  1. Ben Malinski
    Ben Malinski Guest
    question for 80\'s blazers with mechanical clutches
    Where exactly does the clutch return spring connect to? One end is connected to the clutch fork but what about the other end? Does it connect "somewhere" toward the front of the truck on the frame or toward the rear of the truck frame? I'd like to know where both ends connect to exactly. Thanks!!
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Re: question for 80\'s blazers with mechanical clutches
    Mine is connected to the clutch fork and then hooked thru a 1/4 hole already in the side of the frame in front of the front shock mount.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    same for mine. There are a few holes it should fit in and it doesn't really seem to matter which one you use. Probably would depend on your adjustment. When I had mine adjusted really far out on the adjuster(I actually made a longer adjuster) it was raelly stretched in one hole and looked fine in another.
  4. Ben Malinski
    Ben Malinski Guest
    Thank you for the replys!
