Question for Donovan? Or anybody else that has done this
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Aug 24, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Donovan I have a question on the 6 lug 14 bolt FF. You said something about turning down the axles, what do you mean. Do you mean that you had to grind down the end of the axle to fit the 6 lug pattern, or did the whole axle have to be turned down as in on a lathe to make the diameter smaller?
    86 Jimmy 4"lift 35"MTRs locked front.Other cars 69 Firebird w/525 hp,and 70 GTO <a target="_blank" href=http://www.geocities.com/modifierperformance>MY vehicles</a>
    <P ID="edit"><FONT class="small">Edited by DesertDueler on 08/24/01 11:41 PM.</FONT></P>
  2. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: Question for Donovan?
    Or if anybody else knows. The reason I ask is because I to keep the axles as stong as possible. I do alot of hard rockcrawling.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The hub and the end of the axle are turned down to 4.170", the 8 lug holes are filled in and the hub is re-drilled to 6 lug and allen bolts are used to hold the axle in. Donovan had some pictures up a few weeks ago.</font color=blue>
  4. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    If you really want maximum strength, then you should leave it an 8 lug. You can get 8 lug 15" wheels pretty cheap.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Chris
    thank you for your help!!
  6. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Sorry I was out of town and didn't get it to sooner. I had to turn down the hub and the axle to 4.170" which is toyota size which was about .100" on each side of the hub not that big a deal. The axle is the same diameter at the hub so you have to turn them down together. If you have any question let me know. Here is the pictures <a target="_blank" href=http://www.rustbucket.rockcrawler.com/photo.html>http://www.rustbucket.rockcrawler.com/photo.html</a>
    Donovan
    Nitro Fumes makes me Horrrrny
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thanks Donovan. Now all I need to do is find a 14 FF. Once I get one Im sure I will have questions. Thanks for your help again.
