question for ppl who like the 73-80 body style
Discussion in 'The Garage' started by K5-newf, Sep 8, 2006.
  1. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    can the front end off a 73-80 fit on a 81-86 i know it can be done the other way around but i was planning on buying somethign newer and with less rust on and put the older front end on it cuz its hard to find a decent blazer around here
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Lots of poeple switch the front ends on the older ones to new ones. Heres a list you will need. The entire front clip. Yah thats about it. You need the radiator core support too. I haven't done this but I think it would be pretty easy
  3. K5-newf
    Nov 5, 2005
    236
    canada
    sry i must of got my question wrong but i ment to the other way around put the older font clip on the new body
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It is only logical that if it goes one way it will go the other way:D . Granted there might be some wiring issues that need to be worked out but it will work. Think about it for a minute.
    Ira
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I think the biggest issue will be the cowl and windshield wipers.
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    "I think the biggest issue will be the cowl and windshield wipers."
    Yeah what he said, I am not sure how that would be done, some fabbin would have to be done, everything else should be pretty much bolt on I guess.
  7. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    just swap the fenders.
  8. K5-newf
    Nov 5, 2005
    236
    canada
    but arnt the cowls different on ..... the older is pretty much under the hood and the newer ones got a panel in front of the hood and window
  9. bayou blazer
    bayou blazer 1/2 ton status
    Jul 16, 2004
    176
    la
    I know when I did the old to new swap, I needed to put the newer longer wiper arm attachment things to clear the newer cowl piece. you would need the shorter ones so the wipers would not hit the old hood. Since the hood hinges bolted to the fender on the older trucks that would be no problem. It should be an easier swap to go to the old style
