Question for Realsquash
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, Sep 22, 2000.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Where did you stick your Fuel Injection Computer at. I have a 4dI Projection System that I had on my landcruiser and I am going to put in onto my Blazer and was just wondering where is a good place to put it. Thanks
    Donovan
  2. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    I mounted it to the heater-duct behind the glovebox. I mounted it with the harness sticking straight up and over the heater control cables and out the firewall. The 4Di is thicker than my current GM ECM, but it should fit (i used to have a 900 cfm 4Di). Keep in mind, my truck is a 77 with A/C (well the ducts anyways!).
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  3. Donovan
    524
    Arvada, CO
    Cool sounds good to me. I will look at that tomorrow. Did you pull the glove box out so you could mount it? How did you like the 4DI setup? I know it is not perfect but I guess I have it so I might as well use it.
    Donovan
