Question for someone with a stock blazer with a 208 or 241.
Discussion in 'The Garage' started by mplogic, Aug 8, 2002.
  1. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Can someone get me a mesurement of how far your slip yoke extends out from the seal on the t-case?
    Here's what mine looks like after the lift and all:
    I was thinking it should be an inch or so closer to the t-case, but I forgot to measure it before the lift and swap.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    No problem. That may be the only advantage of a slip yoke. It can extend out a good amount with no adverse effects. Just make sure there is still a good amount engaging the output shaft. That is about what mine looks like right now, and I have had the rear axle at full droop.
    John
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I think mine might stick out a little farther than that but not much.
  4. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    Ok, so I guess around 2.5" is about normal?
    Thanks guys.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I measured my 208 from the seal to the backside of the slipyoke and got 3'' when it was stock. After an ORD shackle flip and 1 1/2'' block I ended up with 3 1/4''. I'm not saying this is "normal" but it's what I got /forums/images/icons/wink.gif
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Im no expert, but I have always been told that 1.5-2" is the optimum range.
  7. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    thats how far it should stick out of the yoke ?
  8. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    my slip yoke on my 241 sticks out a little past 3 1/2" is that too much ?
