Question for the Computer / Network Gurus around heree
Discussion in 'The Lounge' started by Eric M., Feb 8, 2007.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I know there's gotta be atleast one networking genius around here.
    Here's the question. I've got CAT 5 through out the house. I shoulda gone wireless years ago, but, that's a whole other issue. Now I have a TiVo unit with a network connection in a room where we use a laptop from time to time. I can't run another CAT 5 to that room (well, I'd rather not). Is there any kind of switch I could install? I know I can't use the laptop and TiVo at the same time, but, I'm wodering if there is a switch I can toggle between the 2 without having to unplug and plug the CAT 5 connetion.
    Thanks,
    Eric M.
  2. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    Could you use a router to split the signal instead of running a new Cat5?
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    You need a hub.
  4. uberbeans
    May 14, 2004
    564
    Is a hub the same as a router?
  5. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Oh man, you gus know as much as I do!!
    I have an 8 port switch (also know as a hub). I can connect up to 8 computers to my network. The switch (or hub) has an uplink port which allows me to run my DSL connection to a router which then plugs into that uplink port and gives internet connection to all computers on the network.
    I need to know if I can split or switch the end connection of one of the ports from the switch.
    I wonder if you can run a switch off of switch?
    Anyone?
    Eric M.
  6. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    Is the Tivo part of a satelitte connection and the laptop is over DSL,...or what is the configuration? Not sure if your dealing with two different network demarks or if this is all the same network. Need a better picture of what the layout is.
  7. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    291
    Truckee, CA
    You can run a hub off of a hub, you connect the uplink of the last one to a regular port on the next one up the chain. If i remember correctly, that uplink allows you to use a regular cable, instead of a crossed cable.
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Good suggestion, might help if you know what I'm doing! OK, sooo, I got the TiVo box tweaked by some TiVo guy tweaker. It now has a CAT 5 connection and can hook up to a computer network just like a computer does. I'm not sure how or if it interacts with the other computers on the network. What it does do is allow TiVo boxes on the network to share recorded programs.
    Example: My TiVo is in the living room, I watch reruns of Monster Garage and American Chopper. The girlfriends TiVo is in the bedroom, she watches Merge, Knots Wedding, Bridzilla and every baby show ever made. This set up will allow me to watch my shows from the bedroom and her's from the living room without double programming on both TiVos.
    Make sense?
    Thanks,
    Eric M.
  9. nschingeck
    nschingeck Registered Member
    Jul 12, 2006
    23
    Colorado
    You can get a 4 port hub (switch) pretty cheap at Best Buy, or where ever. Unplug your tivo or laptop and plug that connection into the new hub on the up link port, then plug the laptop and tivo into any of the other ports on the new hub. You want to make sure that the one you purchase is a hub and not a switch otherwise you may need to configure it to work properly.
    Hope this helps.
    Nick
  10. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Cool, thanks. So, just make sure I get a hub and not a switch?
    I'll give it a try.
    EricM.
  11. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    The other thing you could do (and this will limit your speeds on file transfering on your network) is use 2 pairs per connection. Each cat 5 cable has 4 pairs but a network connection only uses 2. You will have to do alot of cutting back and get a dual wall jack in the room. You will also have to cut the cable back and put 2 ends on it at the switch so they both become active. I in no way recommend this and would just get another switch and hook it up.
  12. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    yes
    what you need is actually called a network switch. what you do is run your 1 connection into one of the ports of it (generally they come in 5,8,16,24) then a line to each device in the room.
    thats it thats all.
  13. CustomChevy
    Jun 29, 2005
    4,328
    since there is apparently some confusion here are the differences.
    a router: A router is a device that directs traffic. it accepts one incoming feed and translates it to the devices attached to it. It uses a technology called NAT (or Network Address Translation) to give the computers you connect to it internal addresses to use. Having more than one of these on a network is bad for home use, they will fight. Some bigger enterprise networks use more than one, but thats another story. The 4 output connection ports on your average home router are not actually part of the router, its a built in switch saving you from having to buy one. REAL routers only have 1 output which is generally run to a switch (see below)
    A hub: A hub is nothing more than a dumb splitter. It takes what comes into the uplink port and sends it to every other port regardless of if thats its destination. Theses are old devices and are generally not useful anymore
    A switch: Aswitch is a smart splitter. it knows what addresses on the network are connected to it, and directs any traffic coming its way to to the correct port (more efficent than a hub).
  14. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    Nothing wrong with running 2 routers, get 2 seperate subnets going to keep your wireless serperate from your wired network. That way those pesky buggers using aircrack can't get my porn.
  15. CustomChevy
    Jun 29, 2005
    4,328
    you dont need 2 routers to have 2 subnets going.
    use 172.16.x.x and a subnet mask on router and computers of 255.255.0.0
    you can all machines on either subnet will talk nicely :D, but there is alot of scanning involved to find machines on a classb
    also putting a router on a router basicly just adds another switch and dhcp (read up on ARP as well) to the mix, it works for the most part, but in reality is silly, and prone to having to reset routers.
  16. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm getting confused now. Can I simply run one of the CAT 5 from my 8 port switch to any of the ports in a 4 port switch in the other room and then plug in the laptop and TiVo to other ports on the 4 port switch?
    Thanks,
    Eric M.
  17. CustomChevy
    Jun 29, 2005
    4,328
    Exactly
  18. uberbeans
    May 14, 2004
    564
    This was a GREAT explanation. It really cleared up some things for me.
  19. kgillyk5
    May 29, 2003
    1,830
    Fultonville, NY USA
    Hub= Layer1: Physical Layer...the actual voltage on the wire that represents a 1 or a zero. Dumb splitter as described above. Every node sees the same signal.
    Switch= Layer2: MAC Layer...each node recieves only the traffic that is destined for that node based on the HEX MAC address of the NIC card of that node.
    Router= Layer3...Routes data between network gateways to allow communication between switched networks.
  20. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Eric, install THIS small Linksys switch in the room with the TiVo and your laptop. It's tiny and cheap and works great. Plug the TiVo and laptop into it (and still have a few open ports to plug in other toys!). :cool1:
