Question for the experts!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mikeperez22, Sep 13, 2004.
  1. mikeperez22
    mikeperez22 Registered Member
    May 11, 2004
    41
    How do I remove the fuel filler neck from the truck. I have removed the screws through the bed floor and bed side, and I removed the outer and inner seal, but I can tilt it back because it strikes the bedside. Any ideas??
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    it should just slide out. If i remember correctly you have to pull it out then rotate it a bit then push in toward the inside of the bed.
