question for the experts...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudrunner78, Nov 17, 2001.
  1. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    ...my buddy has a 91 K-5 with power window in the tailgate, where do you get the motor for these windows, he can't find one anywhere in these parts. Also it might not be the motor this is the problem. window rolls down but not up, you can hear the motor while it goes down but no motor noise when trying to put it up. Thanks jesse
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Scope out two blue wires going to behind the latch on the driver's side. Its a lock out switch that prevents the glass from going up when the gate is open. They always malfunction and prevent the window from going up. Just simply bypass that switch and it should roll up. Check to see if the wires going to the gate are all right too, along with your switch. Orange is a constant hot for the switch that is key operated on the back, brownish tan is for down and blue is for up.
    Suburbans, wagons, and Blazer all use the same motor. Your GM dealer may still have access to them.
    "I ain't nobody, dork."
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    well i'm not an expert but we carry them at pep boys.....80 bucks....a little pricey for a dinky little motor but its worth it...also make sure its the motor that needs to be replaced....mine went dead and all it was was the safety switch so that u cant roll up the window up when the tailgate is down.....
    boy do 3:08's and 35's really SUCK
  4. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    GM's switches in these things suck. Mine is intermittent at best. If you need new parts try LMCtruck.com
    <font color=black> -Tommy
    <font color=red>"To secure peace is to prepare for war..."
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Could also test your motor too. Just hook it up to a battery and see what happens. You'll probably have to have in the tailgate to ensure it has ground.
