question for the garage nuts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by asterix, Dec 20, 2004.
  1. asterix
    asterix Registered Member
    Jan 9, 2004
    96
    Broomfield, CO
    I just got a new transmission and xfercase. i want to clean off the grime and oil off the outside. Do you guys use a big tub or what do you place it in to jeep all the junk from flowing into the sewer. was thinging of getting a parts cleaner but i do not think they are strong enough to support a tranny.
    Any thoughts??
    Brett
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I'v ealways taken it to the local car wash, placed it on the floor. Then sprayed it with 1-2 cans og GUNK and hosed her down. May not be the most environmentally friendly method, but it has worked for me. However, the last time the guy working at the car wash yelled at me. I was almost done and he told me to never come back. I said I wouldn't (when he was there) :D
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    doing the right thing
    you can use simple green... its easier on everything than kerosene (engine degeaser/gunk) and is bio-degradeable
    the right kind of car wash will have an oil separator just for what you want to do... barring all that you can wash it outside and spead a bunch of kitty litter (which is dg) that will absorb the grease... you can pack it up and landfill it... you can burn it...
    but theres no way to get rid of pollution... just transform it...hopefully into something less damaging to the environment....
    above all you dont want to flush to a storm drain... thats a straight trip to the water....
    My 30 gallon parts cleaner( carolina brand) will hold a tranny or transfer case without damage to it...it also has a catcher for big chunks of crap and dirt and a stopper to fill the basin (about 5 gallons or so) I cant throw something heavy in there but I can place it in carefully without any wear or damage... its probably 14 ga steel and i use a grate on the basin bottom for heavy stuff
    I use 5 gallons of JET A fuel as the deagreaser mixed with 20 gallons of water... I line the tank with a plastic bag... the jet a and water dont mix.. the grease is heavier then both the liquids and falls to the bottom... I can strain the jet a out/ flush the water and am then left with a plastic bag with grease for correct solid wate disposal... Ive only had to do it once in ten years( I am careful to scrape the crud off first)... the added bonus is that the jet a leaves a slight residue on bare metal so it doesnt rust... it doesnt clean as easily as noxious solvents but its way better than the water based citrus crap they try to sell for parts washers... and cheaper too
    commendable post... I appreciate you trying to do the right thing
    cam
    ( I use my steam cleaner on the slab and do the kitty litter number... I scrape the really heavy crud off first)
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I just cleaned off an axle I am getting ready to install. Placed it up off the ground on jack stands, applied liberal amounts of kitty litter underneath (doing this under my carport), and soaked it with brake cleaner and let it dry. Went after it with a wire wheel, and when all the crud was knocked off, soaked it again with brake cleaner, let it dry, and wiped it down. Then painted it. The kitty litter caught all the liquids, then I bagged the kitty litter, and tossed it in the trash.
    John
  5. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    So what do you do ? Drive down to your local international airport with a five gallon gas can and tell the fuel truck to filler up with Jet A :laugh:
    Dan...
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hahahaha if you need some JP5 i could get you all you wanted and more,
    FREBIE:xmas:
  7. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    car wash
    just take it to the local car wash when the owner is not around and squirt it down with gunk and presure wash it down. At those car washes all the run off going into the sewer system not the storm drains, but it would be a good idea to do it late at night, I'm sure it would tick off the owner.
  8. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    yep.. showed up at JET services at redding airport and bought it right at the pump...
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    car wash works great put it on high and hot, also kerosene will cut all the junk of fit real quick, with a nylon brush and a green scubber pad, will be clean in about 5 minute, then rinse and dry and paint, all done
    plug all holes and dont go crazy around the case vent hole on the top of the case!
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    depending on if it's painted or not and if you care about the enviroment oven cleaner works well too.....................:smirk: :whistle:
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    probablly wouldnt work for you but when I had my T-Case out i just took it to my farm we have a hot-water powerwasher. I just spread the stuff out real light on the grass. not enough there to do any real damage. Cant be as bad as all the chemicals sprayed on the ground every year, lol
