Question for the Gear Guru's!
Discussion in 'The Garage' started by OrangeCrushK10, May 11, 2004.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Question for the Gear Guru\'s!
    What gears do you guys think I should run?
    I've got 1 ton front and rear, np205 and sm465. I'm going to be running a 500lb torque motor that won't rev beyond 4,000 rpm. I'm looking at probably around 40" of tire (give or take a little).
    I have no need to go faster than 75 mph. If I want to go fast I get my BMW.
    SO! What should I look at getting? I don't know a whole lot about gearing so some help would be great! /forums/images/graemlins/confused.gif
    THANKS!
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: Question for the Gear Guru\'s!
    4.88 will get you about 60mph in the 2500rpm range
    there are a few gear ratio calculators online if you try a google search
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Here is the best gear calculator on line:
    Florida 4x4
  4. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    http://www.florida4x4.com/tech/gearcalc.php
    4.56 puts you at about 2500 @ 65mph with 39's
    I wouldnt go any lower then that if you are going to drive it on the freeway !!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. OrangeCrushK10
    Jan 25, 2003
    1,425
    Thanks Guys! I think I'm going to go for 4.88's
    CK5 is the best! /forums/images/graemlins/thumb.gif
  6. johnc
    May 6, 2004
    68
    O.C., CA.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
