QUESTION FOR THE PROS
Discussion in 'Audio' started by balzer, Feb 17, 2001.
  1. balzer
    balzer Registered Member
    Jul 31, 2000
    39
    about 2 weeks ago i pulled out my amp, and speaker box, out of the back of my jimmy, so that i could have plenty of space when i tinted my windows. ever since then my radio has not been working but my cd player has, and tonight when i went to reinstall my speakers and amp, the amp was getting power but it wasnt coming on, like there was a bad connection in the remote wire, but i checked it and there wasnt. and when i put the remote wire to the power wire of my amp my radio tuner would work, and if i had the remote wire was hooked up to the amp and the power wire was hooked up to the amp and i put a jumper across it, the amp and subs would work and the radio would work but the amp would stay on all the time. somebody please shed a little light on my problem. i am running a jvc head unit and two jl audio subs powered by a coustic 700 watt amp. thanx
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Make sure that you have the corect "turn on" wire. Some radios have an ant. lead and a turn on lead. Make sure that you have the corect one. Also, you can tie the turn on lead to the igniton wire behind your radio, that the amp will turn off when you turn the ignition off.
    <A target="_blank" HREF=http://dblazer.coloradok5.com>http://dblazer.coloradok5.com</A>
