Question for the steering gods
Discussion in 'The Garage' started by pplblazerdude, Mar 12, 2004.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    I Have recently done a frame swap on my blazer and previous to the frame swap i had a 4 inch lift so i put it on the new frame. I was cycling the steering today when i noticed that i have twice the steering to the left as the right. Is this normal or is something wrong? Can it be fixed?
    Clint
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm guessing you have no steering correction of any form? Its normal for lifted trucks, thats why you need things like drop pitman arms and raised steering arms.
  3. pplblazerdude
    Jul 18, 2002
    242
    I have a raised steering arm. I have no idea what to do.
    Any help is muchly apreciated.
    Clint
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    was the pitman arm removed? maybe the shaft was not centered when you pressed it on??? /forums/images/graemlins/thinking.gif
  5. pplblazerdude
    Jul 18, 2002
    242
    we have done nuthing to the steering box but take it of the frame and stick it on the new frame.
    Clint
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Maybe you will need to undo the draglink and recenter it on the threads to start from scratch. Make sure pitman arm is on correctly, then adjust draglink to center steering wheel. /forums/images/graemlins/k5.gif
  7. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    I think Stallion's right on this one-pull the pitman arm off the shaft, then turn the wheel all the way to the left (or right), then count the number of turns to go full lock to the opposite side. From that point, take the number of turns and cut it in half, then go back to the left that amount, and you're centered.
    So, if it takes say 7 turns to go from full left to full right, then you'd go back 3.5 turns from the right-make sense? From there, once you're centered, put the pitman arm back on and tighten everything down again. If your steering wheel is not centered, you can either pull the shaft off the splines, spin the wheel to center then reconnect, or loosen the drag link and adjust it that way. Oh-make sure your wheels are strait ahead before you do adjust anything.
    Hope that helps, and Best of Luck,
    Mike
  8. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    ummm, the pitman arm only can be bolted correctly in one spot on the steering gear box. if you got the bolt to go through the pitman arm, it is on correctly
    it sounds like you need to adjust the draglink length. jack up the front axle and get both front tires off the ground. turn the wheel to the direction that you seem to be short on and look to see how far away the knuckle is from the dead stop. extend or retract the length of the drag link until that knuckle is close to touching the dead stop. if you turn the wheel back to center, the front tires should be in the ballpark. make some final adjustment on the draglink and you should be all set.
  9. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    the pitman arm can be installed in 4 different places(4 different master/wide splines)
    the box gets centered, then the arm installed in the correct location
    I agree that it is just a drag link adjustment issue though
  10. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    i guess i have never seen an gear box output shaft that has more than one spot for a bolt to slide through. we are talking about 4x4 steering boxes, right?
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    If that's the case why are we busting our asses looking for 2wd steering boxes for crossover steering? I dunno what box you have but my stock steering box will only let the pittman arm bolt on in one position, it is keyed.
