Question for the Tranny experts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Jan 11, 2001.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Installed my Rebuit TH350 approx. 2 monsth ago. Also installed new kickdown cable at this time. Upshifts seem to be great. When I floor the gas pedal at a low speed while in 3rd gear the tranny doesn't kickdown to 2nd Like it used too. Is an adjustment of the kickdown cable needed? or would this be something else? Any inof is appreciated.
    James
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    You should have an adjustment at a bracket by your throttle linkage it is a plastic clip that you pry up and then get someone to push the gas pedal to the floor (engine off) and hold it there and then push the clip back in then drive it and see what you think if it holds the down shift too long then you can go back and adjust it again
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  3. James
    Jun 22, 2000
    179
    Castaic, Ca
    Just bringing to top. All you experts overlooked. HELP
    James
  4. James
    Jun 22, 2000
    179
    Castaic, Ca
    Will start from there. Thanks
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Pure B.S.
    You are just repeating what you head/read.
    Please stop !
  6. James
    Jun 22, 2000
    179
    Castaic, Ca
    Pure B.S. hmm. Maybe you might know how to solve the problem executioner.
  7. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I don't know what BS you are talking about i put a new kick down cable on my TH-350 and had the same problem until i adjusted it just like i explained it earlier.
  8. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Do you have a "shift kit" in the trans?
