question for those who have done lifts/axle swaps at home
Discussion in 'The Garage' started by BIGDAN112686, Aug 31, 2003.
  1. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    alright everyone. ive been lookin around for the tools needed to do a lift and axle swap at home. i have the hand tools needed(got a sears mechanics tool set for last christmas) but i dont have any jack stands or a floor jack. in lookin around im not findin anything that will lift to a height that could allow me to do a 6" lift and 35's or 36's and an axle swap. any ideas?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Harbor Freight has jackstands that will go to over 30" high. </font>
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    all im gunna say is find some 2 feet tall peices of wood, Cut tree trunks, such and such, and you might need a grinder to get those old bolts out, because if the truck lived for any of its life in the rustbelt, they probly rusted in good /forums/images/graemlins/blush.gif. but use natural style jack stand bases, and then put some jackstands ontop of that, that is what i have\had to do when installing my 4" lift kit, and when i recently had to replace my spring shims. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's a hint: You don't have to lift the truck up high enough to fit the lift kit and those tires right away. /forums/images/graemlins/cool.gif I only jack the truck up high enough to remove the tires, then I'll let it back down so that the bottoms of the brakes are just a few inches off the ground (perhaps 6-8 inches to install a 4-inch lift). This way you don't have 5,500 lbs of truck teetering on tall stands, blocks of wood, etc. and you don't have to lift the axles up much to bolt them back into place. /forums/images/graemlins/thumb.gif Install the springs and then you can jack the truck up high enough to install the tires and wheels after the lift kit is in place.
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yet another great post from Harry.
    What he said man. thats how i did it.
    Grant
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Have to agree. When installing the lift have the axles sitting on the ground and then you'll only lift by the frame. A couple short 4x4s(lumber) help also.
  7. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    hmmm...not sure what i missed when i installed mine, but alot of lift was needed with jackstands on bricks...lots of bricks. Yikes.
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I was able to use the 4 6 ton jack stands my wife bought me for xmas to do my spring swap. I was able to jack it up high anough to swap in 4" lift + 1" zero rates in front and a shackle flip in the rear + 1" zero rates and there was still some height left in the stands. Once the axles are mounted you can lift with the jack under the axle tube and move the stand under the tube to fit the tires.
  9. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    yea but we have cheesey jackstands, and the stumps of wood werked perfect with the cheesey jackstands, and by cheesy i mean not high anough even at full extension, and my dad has a wood fetish so it only made sense for me to get the wood and use it, so he could split the wood with his new farm and fleet log splitter later. /forums/images/graemlins/rolleyes.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Tires off is great and easy in the rear, but you will need either a dolly or two jacks to do the front axle. (you can balance it on one, but its a PITA) I've done it both ways. You can also use some extra small tires to move the axles around on. At the very least get some 6 ton jackstands from Harbor Freight. They extend to 2' tall and are on sale right now for less than $20. Of course, the the 12 ton ones are nice but they will cost you $75. Another good buy is the long frame, 3' max height jack on sale for $100. You won't *need* it, but it sure makes things easier. Count on needing a 4.5" grinder, a BFH, some punches, and PB Blaster. BTW, make sure your socket set has a 15/16" deep-well. Last, and its already been said but its important so I'll repeat it, keep things as close to the ground as you can.
  11. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    I second the two floor jacks...
    It gets pretty scary balancing the rig sometimes...
