Question for those with 52's up front
Discussion in 'The Garage' started by Mr.Jimmy, Jan 20, 2007.
  1. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    Im thinking about making the swap but concerned about driveability. How are they on the highway at 65? Do you suggest it for all around trucks or just hill billys?:crazy:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I haven't actually put mine in yet but they are very soft and you will have lots of body lean on the road. If you are worried about on-road driveability than 52's probably aren't for you.
  3. Mr.Jimmy
    Nov 20, 2006
    66
    Albuquerque, NM
    Thanks for the input 383, guess you are the only one with an opinion. What if I left the overload in the pack or maybe even run a dual shock setup where I can remove a shock when wheelin? Be sure to post pics when you are done with your swap.
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    I have them...and DD my truck...im going to 56s soon. As long as the shocks are valved stiff, you won't have a problem. I have no overload in the front, procomp es9000s and no shocks in the rear and have no problems driving it at 75 mph.
  5. 1977k5
    May 26, 2003
    9,992
    130
    Check out this: http://coloradok5.com/forums/showthread.php?t=148725
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I did them on my 71 and love them. I used one leaf from my old 6 inch skyjacker fronts, and cut the overload so it is just a very small leaf. I did however decide right from the beginning to run a panhard rod. Steers great, handle better than before too. I don't have a swaybar and haven't found the body roll to be scary at all.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to run them on my rig, and i will be dd'n it
  8. Mr.Jimmy
    Nov 20, 2006
    66
    Albuquerque, NM
    Man, I really had no idea this site had so much info about it! Thanks for all the help you guys. Guess its time I purchase a membership already!
  9. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I run 56's front--stiff SAW's and can run about 65-70 on the freeway----it does lean but only on turns like on a street
