Question for those with crossover steering
Discussion in 'The Garage' started by big83chevy4x4, May 1, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    how much did it run to do the swap on a d60? also is the pitman arm that ORD sells necessary or can i use the stock 2wd arm?
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Brand new 2WD box $177
    Superlift pitman arm $50
    JKW X-Over arm $75
    Used draglink $125
    New TREs $50
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I think the total cost was around $500 for the full rockstomper kit... sleeved rock rod, tres, beefy bent drag link, more tres, steering arm, and pitman + shipping. Its been a while since I got the goodies... but I am pretty sure it was around that much... it could be done cheaper if you dont need a bent drag link and you shop a bit. I'd recommend getting a Sky steering arm... very high quality piece and cheap too. Someone here on ck5 could prolly make ya a tierod and drag link if you had the measurements... be cheaper than RS...
    j
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i plan on making my own drag link, tie rod. does sky have a web site?
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
