question for those with lockers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GONZO2, Jul 23, 2002.
  1. GONZO2
    GONZO2 1/2 ton status
    Jul 17, 2001
    137
    formerly Great Falls, MT now Lompoc, Ca
    i have a power trax locker in my rear axle, does it take any differant fluid then before? i did not install it so i don't know what oil is in there now.
    just for info it was an open rear before
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    85-140 wt Gear Oil is what is recomended for the lockrites used in warm climates.
    75-90 for colder climates.
    I have noticed mine run a lot quiter if I run the 85-140
    Call 1-800-LOCKERS I'm sure they would send you a owners manual.
    ClickyPowertrax Lockrite Web Site
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Normal gear oil is fine, that is what I use in mine. I think only limited slip units with clutch plates need special oil.
  4. GONZO2
    Jul 17, 2001
    137
    thanks for the replies
    /forums/images/icons/cool.gif
