Question for Wingnutt
Discussion in 'The Garage' started by mtrdrms, Jun 23, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    Ok now I got my chip from TBIChips.com and it worked better than I imagined. Not perfect but a hell of a lot better. the only problem I am having now is the idle is really high. It is around 1000 when I am not moving and when I push the clutch in while driving it stays at 1500 then once I stop it settles slowly to 1000 and so the cycle continues. What causes this? Do you know how to fix this? i havent tried to set it using the IAC method yet so we will see if that works. Any input would be nice. Thanks for all of your help. Andy
  2. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    OR anybody with a TBI?
  3. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    First, double check your TPS voltage, again, it should be set at .54-.56v. Secondly, try to adjusting the idle screw, it "may" still be set a little bit high. Then reset your IAC min air setting. If all of the above fails, start looking for a vaccum leak. Keep us informed.
