Question for you that are side panel mounting you amps.
Discussion in 'Audio' started by BrianDamage, Nov 6, 2002.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I've been reading the post here about mounting the amos in the rear side panel...just wondering how...are you mounting it to the plywood panel rhat you make, or is there some way to mount it somewhere else? (I've never had the panels off of mine, so I don't know)
    thanks
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The best way to do it is to mount the amp to a piece of plywood. Then mount the plywood to the vehicle. By mounting the amp directly to the metal of the car you can get a ground loop which causes the high pitched whine when the RPM's go up.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My 79K5 had the 150 watt Fosgate amp mounted to the sheet metal for 5 years behind these side panels
    No heat problems and no ground loop problem............ /forums/images/graemlins/confused.gif
