Question of the day - 4/5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Apr 5, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Hey all! I started in on the steering arm last night, the one with the three large studs holding it. The damn thing WILL NOT MOVE. PERIOD. I must have hit the damn thing with everything I have... including the kitchen sink! Anyhow... I must be missing something. What is the normal procedure to remove this blasted chunk of God-forsaken metal???
    <font color=red> Check out my rig @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
    <font color=red> I Love My Blazer! </font color=red>
  2. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    Someone today told me to use a BFH. Along with a torch. Heat the bolts up and be careful. Did you put anything on to penetrate and help loosen up?
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I must have blown an entire new bottle of penetrant on that blasted thing... And it was putting some hurting on the hammer I was using! The poor thing is all mushroomed out, and the arm only took a few dings here and there... YIKES!
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Get a BFH, and PB Blaster. SOak it down and let it sit. Then smack it from all angle really hard with the BFH. Main hitting from one side to the other.... It will come off!
    <font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>[​IMG]
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    If the above doesn't work, get a steering arm puller. Sometimes there is no replacement for tools made for a job. [​IMG]
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  6. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    There is actually a tool to do this??? Damn... wish I knew that last night at 10pm as I was pissing off the neighbors... [​IMG]
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    ONE MAJOR THING TO REMEMBER!!!!!! DO NOT HIT UP ON THE ARM!!!! It will cause those 3 cone washer to swell adn it wont come off. You have to work it to the left and the right and at angles. Make sure you dont hit the threads. PB BLASTER IS the BEST!!!
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  8. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    Regarding getting the correct tools... When I did my tie rods I got the first two off w/ no problem and beat on the third for an hour and finally went to autozone to get a puller and autozone told me I could rent a puller for $15 dollars or buy it for $11??? Wife may call me stupid sometimes but not that day
  9. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    The other way is call Stephen at ORD and order a new set of studs and cone washers for 30 bucks. This things steers your truck so I wanted knew ones on mine. Take a sawzall and cut the studs off flush with the top of the cone washers. Take a 1/2" drill bit and drill straight down into the stud approx 7/8 to 1" then take a chisel and walk the cone washers right out. pull the arm off, unscrew the studs and replace them. Now you have saved your knuckles and as a bonus you have knew hardware on the most important part of you truck next to the brakes. Good luck.
    I thought I was wrong once,
    but I was mistaken
