Question on 14b disk brake swap
Discussion in 'The Garage' started by misterfnygy, Mar 19, 2007.
  1. misterfnygy
    misterfnygy 1/2 ton status
    Jan 12, 2006
    199
    Reno
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Off Road Unlimited used to offer stock plates with their rear disc kits. They used the '81 and newer plates.
    I wouldn't use those plates in the pic because theres not enough material around the mounting flange to the 14FF. Get some '77 and newer plates.
    You will still need a spacer made to fit those plates to the flange. Somewhere in the range of 1.25" thick. This is in order to use the stock GM 3/4 ton rotor.
  3. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I do wish someone offered a backing plate style conversion though. Sure does make a brake dust mess.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    If I could get spacers made, and buy new plates, would there be enough interest to buy them? They won't be cheap like most guys make them from scratch, but at least they will contain some GM parts, namely the backing plates.
