Question on 14bolt rears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Aug 23, 2003.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    Is there a big difference in strength between a 14 bolt full floating rear or the 14 bolt semi floating rear.
  2. Michk5
    Michk5 1/2 ton status
    Jul 19, 2002
    139
    Misawa Japan until December...moving to Wichita Ka
    Well first off the ring gear is 10.5 on the FF and only 9.5 on the SF. I can't imagine a reason to run the SF when the FF are a dime a dozen. Just my .02--Matt
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> There's a big difference, not only in the size of the ring gear but just due to the nature of a semifloating vs a full floating axle. On a SF the axleshaft transfers power to the wheel and also supports the weight of the truck via a small roller bearing between the shaft and the axle housing. On a FF the weight of the truck is supported by a hub and spindle assembly just like on a front axle, so all the axleshaft has to do is transfer power to the wheels. More parts, but the FF is a much stronger axle because of it. </font>
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    also, if you break an axle shaft with a ff you can keep driving and the axle will stay in, as where with a cclip axle it will not..
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Which is just a nice side effect of the FF design, and really has nothing to do with strength. /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif</font>
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    arent axles bigger too!
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Possibly, but less spline count. I am not sure of the size of the axle shafts on the SF 14, but they're 33 spline vs. 30. Either way, the design makes the 14 FF much stronger.
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    My ff has 33 spline shafts.
