question on 14ff disc conv.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by topless1tonk5, Feb 8, 2002.
  1. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    i have the brackets and the 78 caddy calipers, sorry for the ignorence but i have never even taken the hub off a ff before, can some one tell me what tools ill need to do this job this evening, i am going to pick up d44 3/4 ton rotors right now, is that what i need? any particular year? thx -- j.c.
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Remove the 8 bolts on the hub that is holding the axle in place. Then................damn, it's been a while, but I think the next step is to move the rectangle piece out of the lock nut. Then use a hub socket (6 prongs) to remove the lock nut. This can be done with a hammer and screw driver too, but will be painful (I used that method the first time), then I think that's it. pull the hub/backing plate out. Man, it's been so long, memory is a little fuzzy [​IMG].
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I just disassembled mine a few days ago, and it sounds a little different so I assume there are two different types.
    1. Remove the 8 retaining bolts on the hub
    2. Slide out the axle shaft
    3. I didn't have a key on mine, but instead had a locking washer behind the first nut, pry these back before unscrewing. I also used a flathead screwdriver and a rubber mallet to work it loose ( 1 light hit) and then spun it off by hand. You can purchase the correct socket at your local parts store (looks like a piece of pipe with a keyed end and a 1/2 drive on the other.
    4. slide off the retaining lock washer (wont spin off)
    5. spin out the final nut from behind the washer
    6. slide off the drum
    7. Unbolt 4 bolts on the backing plate and your done.
    Good luck
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I thought the calipers had to be '76 or '77, but I am not sure it's been a while since I converted mine. I used '76 on mine.
    <a target="_blank" href=http://coloradok5.com/gallery/albuo71>My K5 Stuff</a>
  5. topless1tonk5
    Dec 10, 2001
    98
    littleton co.
    thx- you guys are the bomb! (is that saying still cool?) will i need a hub puller? what size hub socket? j.c.
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    No, it should all come off real easy, unless your drums are worn and have a lip grooved into them. If thats the case, you might need to adjust them loose from the hole in the backing plate before it will come off. the hardest part in all this is getting the lugs out of the drum to remove the brearing carrier. I'm planning on getting new lugs so I just pounded mine out but if you want to reuse them, a press and a copper block would be a good idea.
  7. topless1tonk5
    Dec 10, 2001
    98
    littleton co.
    wont my d44 hub and rotor already have lugs? im confused!
  8. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    No. The rotor simply replaces the drum.
    If it breaks, it wasn't good enough!
    &lt;a target="_blank" href=http://communities.msn.com/Liberation&gt;http://communities.msn.com/Liberation&lt;/a&gt;
    &lt;a target="_blank" href=http://coloradok5.com/gallery/liberator&gt;http://coloradok5.com/gallery/liberator&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Liberator on 02/08/02 06:41 PM.</FONT></P>
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm not sure the front d44 hub and bearings will fit. It was my understanding that you would have to press the lugs off the 14b hub and drum, then reuse the hub and run new lugs throught the 3/4 ton d44 rotor. There may be a way to do what your suggesting but I'm not aware of it.
    Anyone have any ideas?
  10. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    see if these will help
    http://www.truckworld.com/How-To-Tech/ChevyDiskBrakes/Chevrolet-brakes.html
  11. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    J.C. if you have any more questions about the install you can also contact me via pm or email and I can help you out. You will have to press the studs out of your 14 bolt hub/drum and seperate the two then place your new rotor where the drum was and press the studs back in. You do not use the d44 hub.
  12. topless1tonk5
    Dec 10, 2001
    98
    littleton co.
    can they do that for me at napa? will the have to be pressed back in? by the way your brackets appear to be very well fabricated, i am very satisfied. thx--j.c.
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Derbinator, have you or anyone else figured out any neat tricks for making the caddy calipers E-brake mount on top of the axle yet still blead without unmounting them? I don't have the calipers yet but wonder if mounting the whole caliper above the axle as opposed to behind it might put the bleeder in a better position. Then run the E-brake cable to the axle where you pivot a linkage to properly engage the caliper E-brake lever (since the e-brake lever now needs to be moved down instead of forward)? I'm sure if I had a pair I could see if it would work or not but I'm not that far along yet.
  14. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    JC,
    Yes you could have napa do it or if you have an old lugnut put it on to were the studs are not quite coming thru and tap (beat) them out with a hammer. When you put them back in just use a hammer and punch or similar item to tap them in. If the bearings are still in the hub make sure to cover them with a rag or something to keep them clean as tapping (hammering) tends to knock alot of dirt free.
  15. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    BorregoK5, I'm not familiar with the caddy e-brake but as far mounting the caliper on top instead of slightly behind it would just be a matter of rotating the holes in the bracket so it can be mounted in that position. As far as linkage for the the cable I would think that wouldn't be to complicated either.
