Question on Dana 44 Flat tops ****UPDATE****
Discussion in 'The Garage' started by TxK5Blazer, Mar 4, 2004.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I just recieved my ebay purchase today of a set of Dana 44 flat tops. I was looking at them and noticed what looks like one knuckle the tie rod loads on top and the other the tie rod loads on bottom. I think I have a problem? I have emailed the guy I bought them from and am waiting to see if he can correct this .....Guys give me some feedback....Jason
    Here is what he emailed me back does it make sense to you guys....?
    Jason,What has happened is I also had a set of Jeep knuckles for sale last
    week,and I sent you one of them by mistake.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: Question on Dana 44 Flat tops
    Post pics!
    Bill
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I can't get them to load right so if you give me your email I can send them to you ...Jason
  4. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    TTT
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    it sounds like you have a non flat top driverside, and a flat top passenger side.
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    No they are flat tops but one has the tie rod hole upside down from the other.
    Bill
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah that would pose a problem /forums/images/graemlins/eek.gif The flat top pass side is older they were top loading newer ones are bottom loading.
  9. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    well inorder to work on mine they need to be bottom loading. I will wait till I get in contact with the guy I bought them from and see what he can do ....Jason
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are a couple things you can do.
    go hysteer and not use the lower tierod mounts, make the dude send you a correct drivers knuckle, or have someone braze the drivers knuckle and then reem it for the upper TRE hole.
    Harley
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    As far as I know all flat tops are top loading...somebody correct me if I am wrong
  12. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I didn't think about the high steer option that would work. Is there any other things that might be wrong with them that would keep me from using them....Jason
  13. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    When you get a set of flat tops they are top loading. When you get a set of non flat tops they are bottom loading. Key word is "set". Problem comes in when you get a flat top drivers side that is newer with a flat top passenger that is older. They look the same except that the newer style loads from the bottom. Been going through this lately and this is what my investigation has turned up.
  14. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    so what is the answer to this problem...Jason
  15. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The answer is that all GM drivers side knuckles, whether they are from a 10 bolt or a 44 are flat top. It is just the passenger side that changed, since there was never a steering arm mounted on that side. Depending on year, some drivers side knuckles have the tie rod taper up, and some down.
  16. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Get ahold of the guy you got them from and tell him he sent you an unmatched pair
  17. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually I have a few axles laying around here and so far all the flat tops I have seen are top loading but the newer non flat tops come in either top or bottom loading.
    I guess the difference would be the years of manufacture but still no idea which years came what.
    /forums/images/graemlins/thumb.gif
  18. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    my understanding is that all flat top axles were top loaders, i think they were from 73-76, but not certain. all non flat top axles were bottom loaders. that is why i stated that you have a non flat top driver side (yes i know, it is flat and has studs, but not from a factory set of flat tops) and a flat top passenger side.
    so my final answer is that you got an unmatched pair.
    why cant you run a top loading tierod?
  19. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I will have to go hi steer because my springs will be in the way if I go toploading. I think. I am waiting to hear from my machine guy and see what he says....Jason
  20. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I had the same problem with my pass side flat top (I didn't buy a matched pair). I brazed the hole and reamed it out to load from the bottom.
