Question on gearing with a SM465
Discussion in 'The Garage' started by 84CUCV, Jan 17, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I can get cheap axles with 4.56 gears in them. I was going to put this in a 86 K5 with 5.0 sm465 and 208. I am going to run 35s. No plans to go bigger. Dont know much about gearing so i was thinking with 35s and 4.56 i would be OK or am i just way off. as always thanks for the help
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    PM Readymix that is the setup he runs and he just recently went from 36s to 39.5. He should be able to tell you how it worked with the smaller tires.
    Ira
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Highway driving won't be much fun, but it will work. I've got 4.10's, 35's and no overdrive in my K5. The engine is really spinning at 70+ mph. 4.56's would mean even more revs... Right now I have 4.10's, 35's and a 700R4 in one of my Suburbans. Overdrive makes it much more tolerable on the highway than my non-OD rig. :cool1:
  4. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    theres a few here running around on 35s and 4.10s with the sm465...Chevy305 is one of them, and he thinks its the ideal setup...
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK how can i find out what RPM i will be at with that set up?
  6. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    I just swaped a 465/205 in my 84 k5 and i have 4.56 with 35s and i think its awsome on the trail but is to low for the highway. I am swapping back to 3.73s this weekend. But it all depends on how you drive your truck. I do a lot of highway time but the best gear calculator i have found is at
    WWW.FLORDIA4X4.COM
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK link didnt work. thanks
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    2850 rpm at 65 mph with 4.56's and 35's.
    Gearing (4.56) X speed (65 mph) X 336 / tire diameter (35")
    Rene
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    so is 2850 alot of rpms or not? seams kinda high from what i know.
  10. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Too high for my liking, but only if you drive on the freeway much. 2850 is at a conservative (slow) 65 mph too. 75 mph would be almost 3300 rpm...
    Rene
  11. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    336
    Fort McMurray, Alberta
    I usually like to target my small blocks to about 2200 rpm, thats their sweet spot :)
  12. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Ya thats true, I run the 5.0L/SM465 with 4.10s and 35"s. I think its a great all around combo. I think about 2950 is 75mph.
    4.56 would be fine, but only if you plan on not going on the highway much or take long trips in it.
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    That's a little higher rpm than what would be considered ideal for highway cruising, but it's not horrible or anything. There were tons of trucks that came from the factory in the 70's, 80's, and even 90's that would spin that type of rpm at 65 mph, and might even have a higher rpm at that speed.
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    starting to think i should get some 4.10s
  15. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    x2. Ive always been told that you get the best mileage on the highway with the motor turning between 2000 and 2500. anything over that and it will start to drop. on the other hand if most of your driving is around town rather then long highway trips then the lower gears will help it get better mileage cause it will pull itself around better in the stop and go stuff. personally I think 4.10s would be a better choice if its gonna be a dd.
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Only was going to go with 4.56 axles because i can get them for 100 bucks. So i was thinking what the heck. 4.10s are sounding like the way to go now thanks guys
  17. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
  18. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
    I give up
  19. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks for trying
  20. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK a new turn a friend of mine said he found 4.10 60 and 14b that i could get for a ok price. now my question is with 4.10s could i pull off a 38-40" tire and be ok with it? thanks
