question on MAP sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BrianDamage, Aug 12, 2002.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    hey yall
    got a ? about my '87 TBI 350 Blazer...I was having a problem with it giving me a code 33, but the only real time it ever ran bad, was like when I'm having to cruise through a parking lot real slow or something to keep from hitting anybody /forums/images/icons/wink.gif it would stall and also would stall sometimes in 4x4
    I ordered a new MAP sensor from Autozone (I tried to get the AC Delco w/ 1year warrenty (nearly $30 cheaper than form the dealer), but even though their website said they had one, they didn't and I had to a Wells brand w/ 3 month warrenty)
    Anyway, it worked fine for 2-3 weeks...no rough idle or stalls and no code.
    Then it started doing just like it had been
    I just got another Wells MAP sensor in, but I don't want to put it in unless I can figure out why they keep going bad...I don't mind spending $75 for an AC/ Delco, but I don't really want to if it's just going to go bad on me all of a sudden
    I did replace that little tube that runs from the back of the TBI to the valve cover will that help any??
  2. dyeager535
    26,975
    Get a scanner and a service manual. Look whats going on with the system. Either that or head over to thirdgen.org and look/ask around. Two Delco MAP sensors will buy you one scanner.
  3. BrianDamage
    May 14, 2001
    753
    Alabama
    so those scanners are worth having huh? I've seen up there at Autozone, but wasn't really sure if I needed one or not..is any one brand better than the others?
  4. dyeager535
    26,975
    You are going to want to get a "live" data scanner, one that allows you to both capture data from the ECM/sensors, and one that allows you to see the info as its happening.
    I've got an auto x-ray 240 I bought off of Ebay for about $140, used, but had all 3 cables to do dodge, ford and GM. Will do up to about '91 on GM stuff, I *believe* the scanner hookup port (ALDL on ours) changed with the coming of OBD2, which the 240 won't work with. Apparently some of the later scanners work with OBD 1 AND 2, so if you have some later vehicles, a newer one that does both might be handy.
    Of course, with a laptop, you can run the free software online (winALDL.com for one I think) you just need the right cable.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check for any vacuum leaks. Broken or cracked vacuum lines, a loose intake, loose throttle body, etc. Any leaks will cause the MAP sensor to "see" the incorrect engine vacuum.
  6. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    If you can't afford the scanner the map sensor is very easy to test. It reads from 0-5v depending on the vacuum. You could temporarily wiring a voltmeter in to see what values it has, if I remember correctly lower voltage means higher vacuum. Or even take is off the truck hook up the voltmeter and find something/someone to apply a vacuum on the port of the map sensor. Probably not a good idea to ask the wife/GF for this service /forums/images/icons/smile.gif Also check vacuum lines for leaks. Try to figure out what is wrong before replacing parts, the map sensor is a simple device and doesn't usually go out.
    Hope this Helps,
    Mike
