question on polly motor mounts
Discussion in 'OffRoad Design' started by UNCLE CRACKER, Dec 10, 2003.
  1. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    I am getting ready to drop in a new motor in my truck. the motor is a 383 around 425hp and 425tq. my question is do you think it is better to run the polly mounts VS. the rubber? I have heard of people breaking tranny housings and I was wondering if the polly bushing help this problem? also do they make a big difference in the vibration you feel through the motor?
    thanks
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You definitely feel more vibration, that's just the nature of the beast, it's hard to have a stiffer mount without it being, well, stiffer.
    As for breakage, I'm a big fan of having the motor mounts at least as stiff as if not stiffer than the transfer case mounts so putting the HD poly mounts in would be a solid upgrade, at least in my opinion. This way the motor's not trying to torque against the t-case mounts. I'm also the guy that sells the stuff, but the reasons are sound so you know I'm not blowing smoke up your kiester.
    Hope this helps /forums/images/graemlins/thumb.gif
  3. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    so in your opinion you think this helps against tranny case breakage
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup. The idea is the motor can't move as much so it can't twist against the t-case mounts and break the trans housing.
  5. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    I guess you will be getting a call from me so i can order those mounts.
  6. Alaska Offroad
    Alaska Offroad Registered Member
    Apr 14, 2002
    79
    Alaska
    Upgrading to ORD Poly bushings on my engine mounts is one of the best mods I have ever done, and I have done LOTS of "extreme" mods. IMHO the increase in vibes is barely noticable, and the benefits of engine controll is more than worth it.
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Not to hijack a thread, but....
    Stephen, I sent you a PM a while ago regarding raised motor mounts. No answer so I figured I'd ask you here: Do you make your poly motor mounts in a raised version? I need 1/2-1'' to get the motor to clear my crossmember and to keep the mechanical fan off the front crossmember since I raised the t-case a bit. Also, what would pricing be on such an item?
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We don't have a raised version but I was able to build some spacers for my crewcab that worked pretty good. They raised the motor about 1/2". They're cut out of 3/4" plate. My turbo exhaust manifold was hitting the frame so I picked it up a little.
    I don't know if we're going to build anything to raise the motors, the spacer plate is the leading candidate right now.
  9. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Just to be sure, does your motor mount kit come with both the frame and block brackets (I see the block bracket in your picture).
    Thanks!
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, the comp style mounts come with both sides. Our HD daystar mounts are just the frame side and are a little cheaper.
